edgutgesell
- Jul 18, 2004
- 144
I have a 1987 150 Yamaha. This past fall I had an oil injection problem where the oil level sensor in the oil tank on the engine would not cut off the pump in the large tank causing the tank on the engine to overflow. This caused smoking and high oil consumption. The problem has been resolved by replacing the oil control module on the engine. It was pure luck that I didn't burn up the engine because the red low oil warning light (incandescent)was burned out, and I checked the large tank just before the tank was totally empty. Another mile and there would have been didaster!! I would like to replace the incandescent warning lights with light emitting diodes (LED'S)<br /><br />My question is:<br />While running, the voltage meter at the console shows a voltage above 12.6V (about 14+ volts)and drops down when idling. That voltage seems to be unregulated. Are the voltages from the oil control unit regulated and if so, at what voltage? LEDS are voltage sensitive and higher voltages decrease their life span. If the voltages out of the oil control unit are regulated and put out a steady voltage, then I can design the LED warning <br />circuit without adding a voltage regulator to my <br />circuit design. I worked as an electronic engineer in the past, but my knowledge of outboard engine electronics is pretty poor. LEDs can last about 10,000 hours which means that if I design it right, I won't ever have the burned-out <br />bulb problem again!!!
