hull extension in progress with pics
Status
Not open for further replies.
drewmitch44
Re: hull extension in progress with picks
Whats the ballpark cost up too? Juse wondering if you could have just bought a brand new boat with what you have spent? Thanks and its looking sharp!
oops!
not yet.....thats after the new motor.....
i allways could have bought a new boat, but they all look the same.
the budget was 25k for the whole proj....including, motor drive, tower uph and paint
oops!
I own a larson cruiser with a stepped hull. It rides noticeably flatter and much quicker than similar boats its size.
Doug
hi doug.....what size and what pkg? are you over 30 feet?
my comments were directed towards the smaller "under 25 foot" class
douglee25
Not quite 30 ft' yet. :D The boat is a 27' Larson Cabrio Cruiser equipped with a 7.4l Volvo Duo-Prop package.
Doug
redfury
Must be seeing the light at the end of the tunnel now, eh oops! ?
Looks really good....Y'know it's going to be a shame that most people won't know what went into that boat when they see you grinnin' behind the wheel in it while popping up on plane ;)
oops!
heh heh heh
kinda like lund's woodwork/glass job in his resto.....its soo purty ya hate to cover it up..!
we are getting very, very close. more long blocking on it last nite and another three hours scheduled for today.
one side is allmost perfect, the other just needs a little fine tuning. then we start on the side gunwhales.....(weve been picking at them little by little. so there wont be too much work on them at all....
the sanding is crazy...! really hard tedious work. running up and down the legnth of the boat with a board, pushing as hard as you can on it.....
we are using 50 grit sand paper. it really chews the filler, but it is still very slow.
each day that goes buy...it gets another step closer to the water!
cheers
oops
oops!
drool, drool, drool.....ahhh air...
ive been working on getting my big compressor back from a guy. if i make headway, then i have got to find a rental company that has air powered longboards.
were just a bout done....another few days. but im gonna keep tryin for the air
redfury
Y'know oops!, you'll end up getting the compressor back the day you finish long boarding the boat. :p
Tacklewasher
How big of one do you need?
I've got a Home Depot 5 hp if that is big enough for you. I fon't want it to be lent out permanently, and will need it back in a couple of weeks (got baseboards to do) but could part with it for a while.
Don't know what kinda CFM a long board needs though.
fishie
i need my pics fix!!!!:D:D Sounds like your making progress bud!! By the way, congrats on your 3000 posts....captian;):rolleyes:
Tail_Gunner
:D You dont miss much, damm good style.....id give it 6 months or a year to completion...no flame here...lot's of admiration....;)
jcsercsa
OOOOOOOOOOOOOOhhhhh CAPITAN OOOPS sounds like my kind of navy !!!!!! lol now you have too times that by 10 !!! John
oops!
actually tackelwasher i might take you up on that for the gellcoat application..
we finished the hull plaining surface tonight.......the string lines are bang on....there is not even a 1/8th of an inch between the string line and the hull..in fact its bang on for the majority of the hull.....
dale says the tollerances we are using are closer than a new hull pulled from a mold.
tommorow night. (thurs) we will be doing a final blocking of the plaining surface.....then prep for glassing on friday night
once the glass is on the plaining surface....we will rais the boat and work the gunwhales.....that will go fast...one day per....(i hope)
ill post some pics of the progress tommorow.
cheers guys
oops
harry styles
Cant wait to see more picks. This is incredible. Do you think you can do mine next? LOL
NoKlu
I'm pretty sure oops! has had his fill of boat resto work and he's still got a long way to go. If he get's near a hull with a chain saw again he prolly couldn't stop till there's just a pile of chopped strand and saw dust !!!:eek: oops! Back away from the Bayliner!!! :D
oops!
i was thinkin of makin it a cuddy......just a quick slice down the keel to widen it, then one half way up the gunwhale to give it more freeboard.
a quick and easy way to turn a 19 footer to a thirty. :D :D
erikgreen
Just take what you have now, cut it in two at the keel, then turn each part on its side and fasten the sterns together. Presto, 50 foot canoe :)
Erik
oops!
Erik
lol...:D
oops!
the hull is now stringline perfect. dead straight......
the thing to do now, is do a minor skin coat, this will fill any minor pinholes, or indents caused by the trowels or putty knives that are too deep to sand out.
over all the hull is straighter than any boat in the yard out front.
to the naked eye, you cannot see a waiver anywhere along the plaining surface.
this was really tough to do as the poly fair shrinks during cure, so we would add a layer one day, wait till harden, then fair it. and the next day or two...it would be low due to shrinkage.
we still have to add the final layer of glass to the bottom and then fair that in, but, at least we know the area to be glassed is straight.
we still have a litttle surface prep for the bow area, but well do that tonight, and then tommorow, its glassing time :D
cheers
oops
Status
