flyhigh123
- Nov 17, 2012
- 112
Took boat out and fuel pump not getting power when key turned to on position. Engine is Volvo gas dp 7.4gl.
I made a mistake when diagnosing my fuel pump and removed the relay and mixed up the wiring.
1st can someone please advise me on the proper relay wiring!
I have 4 cables that ran to the relay: 12v red power
Ground
Yellow power to fuel pump
Yellow/orange cable( I assume this is from the ignition)
The relay is a 30amp and has the following marks: 30,85,86,87,87a
Can someone please advised which color to which number? Reason I ask is I swear I tried every combo.
I know the pump works as direct power to pump powers it.
When the key is in the on position, is the yellow/orange cable suppose to read 12v?
I took a look under the ignition and there is a purple cable. Was hoping to see the yellow/orange cable but that wasn't there. I can't follow the yellow orange cable as its all wrapped up after the relay.
To better understand my engine, does the ignition power go to ecm which then goes to fuel pump or does the ignition go direct to fuel pump relay?
Ground
