Bayliner 454
- Aug 7, 2011
- 2
Hi All,
Hoping someone can shed some light on my issue. Have a 74glplkd carbied engine production number 3868626. Have been having fuel problems with it and have been right through the system and come up with the following issue.
Electronic in line Fuel pump is supplied power via a relay only on crank ie will only power the pump when you are turning the engine over. On the switching side of the relay there are two wires coming in to it. My question is should this relay have power to the switching side from and ignition source (key, alternator, ignition module) so the pump will run when the engine is running or the key has ignition on.
Currently pump needs to lift fuel approx 2 ft to carby. Engine runs perfectly until you get to approx half a tank or earlier in rough seas and then seems to starve for fuel. Take it head pressure in the tank keeps fuel up while the tank is resonable full. I have run back from the reef twice now on jeery cans mounted above the carby level and engine doesn't miss a beat.
Should this pump run all the time and if yes where does the power supply come from??
Any help would be greatly appreciated.
