Re: You Know The Saying "trailer is worth what you paid for the boat" **I Disagree**
I have a welder and know how to use it also. Have you seen the pics? There is nothing to weld to...
Yes, I saw the photos. That area is a junction of three, possibly four, pieces of structural steel. From a photo one can only speculate what caused the failure. This area may have had too much heat when it was manufactured, leaving thin metal next to the weld bead. Or it simply could have rusted there since weld bead areas tend to start rusting first because of the heat, and the inside cannot be painted. Throw in some salt water, and there you have it. Who knows? Should the dealer make it right? I think so. Only you can decide what right for you is.
It is hard to say from photos, but that area
is totaled. So, no, you couldn't weld to
that area again. But from your photos it looks as if you could cut out the tube and cross supports, weld in new pieces, wire brush, prime, and paint, and get on with it. If the boat is that good, I would take the $250 and buy some steel. That would be right for
me. Depends on your goals. If the goal was to get a cheap boat- you did that. Making a point on principle is usually not productive.
I just need to know that I did my part to make them think twice about selling unsafe equipment and just slapping inspection stickers on trailers without even looking at them...
I agree with your point here and if you have the time and desire to make that point go ahead. I commend you. But I would tend to get in motion and either buy another or fix this one.
I will forgo any money or replacement trailer if you would just call me.
Now I am getting confused...
I think if I show up and I was unwanted there I could be tresspassing. I am going to stop calling and emailing because Im starting to think it may be harassment.
Now I am know I am confused. Unless they have already given you notice against being on their property, you should go get your check.
For a $1000 boat, 25% off is pretty good! Maybe the dealer knowingly bilked you... But what is
your goal? If it was sending a message I think you have sent it and I would be cashing that check, movin' on. Life on the water is good, man!
