FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Hello i have a Yam 9.9 2stroke model 2003. I want to know if there is a way to be 15hp. I think they have same cc.
A mechanic told me that i have to change the reed and the zigler. is that correct?? Really is so simple?
This is a very easy upgrade. You need to change only three parts, the reed cage, the pilot jet and main jet - these parts are the only differances between the two engines. The 9.9 engine uses a 4 petal reed valve while the 15 hp is a 6 petal unit. Total parts cost is about $85 and it takes about an hour to do - clean the interior of the carb while you are at it and put in a new set of plugs (same heat range) Also it's time to change the water pump impeller or you risk blowing it up. - Bob
