wiring help please
jlh3rd
Ensign
according to the pre 1994 force engine harness diagram....purple is his tach wire coming from his engine harness.
jlh3rd
Ensign
I’m re-wiring my pontoon, got all the accessories wired and ready to go, now it’s time to work on the gauges and ignition system, it’s a total mess inside my console! No real wiring diagram, I looked up my bot and engine and the wiring guide I got has wires I don’t even have. So anyways. This part is in my console, it has a wire coming from the key switch to an orange wire from the engine wiring. Any idea what this is? Trying to track down one part at a time. The part I need to know is the 1st photo. The 2nd is the mess I’m working with. I’m trying to do 1 at a time I don’t want my boat to become inoperable bc we go to the lake every week.
is the harness from your motor a mercury harness for that motor?
or is it the harness from/for the Force motor......
i should've asked sooner....
Jasindude1
i dont think its a Merc harness, he might of re-used that force one, do you have the force engine harness diagram? or at least the colors? I do think purple is tach
Jasindude1
ok, I think i have somewhat of a idea, Im gonna try and track down the wires today I got a wire detector, its harbor freight so who knows how it works, Im also trying to find the main battery wire, would it go into the remote controls first? and then into the console? Im trying to wire a battery selector switch so I have 1 battery that runs all the ignition and engine and one that just runs accessories. But i assume the main power would go to something first before it goes to the ignition right? bc as of now the red wire coming from the controls is directly into the key switch and then the purple from the key switch i assume is key on 12 volt which is wired to gauges. So would the main power from the battery go directly into the console or would it go directly to the control box 1st? or is that red wire going to the ignition directly from the battery? any ideas? thoughts?
jlh3rd
Ensign
yes....post #18 ...but here it is again.....not a diagram...just code colors...
jlh3rd
Ensign
um...I don't wanna lead you wrong. I cleaned up my pontoon's wiring but I didn't re-wire it.........
My controls don't need a choke, and are separate from my key switch. And my tach has factory wiring, there is no separate 3wire plug as some older boats might have in their control box..Mine is factory and hasn't been messed with. Once someone does what appears to have been done with yours, all bets are off and it can be...interesting...
This being said....
Positive power gets branched off from the battery, thicker gauge wires to solenoids, starters....smaller gauge to key switch, and then to activate solenoids and relays, hot wired items ( bilge pump)...it's not like it necessarily goes here first and then there...
somewhere there is a red (hot) wire going to the key switch ....here is a pic of mine with the fuse from the battery into the harness....I think it goes to my key switch.....it also might branch off...
Anyway...if it was my boat....because of the mess ....I would get my multi-meter and see exactly what each terminal on the key switch shows when off, on, and start...Especially find out which termina/s show 12v with key on as you need a 12v, key on source for the instruments....also, write the color of the harness wire connected to that terminal...
if your motor starts, stops ok, obviously it's wired right at the key switch for those functions......confirm the tach wire (purple we think), confirm instrument power terminal...try to get correct color wire from the harness to key switch....
I run two batteries but i don't know specifically how to separate and use one battery for just accessories....how would you charge it?...adds to wiring headache it would seem....
My setup measures battery charge and selects engine charging to the battery that needs it, but I can select #1, #2, or both to use, but6AEEEA69-E22C-4E05-B279-485E0F2557C2.jpegI can't separate one battery for one particular job....
