Which Paint should I use?
shaunlaf
Hello,
This is my first post... and I am happy to have just spent my first summer as a boat owner. I'm hooked.
I bought the boat, a 1980's restored 27' pontoon boat with a 60hp Merc engine on it, and after it's first season in the water, I'm seeing that the paint on the bottom of the pontoons need some attention as there are spots where it's warn off, etc.
I want to know how to fix this, and what kind of paint I should get. I started to look it up but got confused quickly... any help for a noob?
Bob_VT
Re: Which Paint should I use?
Metal pontoon or fiberglass? Is the boat left in the water or trailered? Fresh water or salt water?
shaunlaf
It's a fiberglass pontoon that is left in the water for the summer season. Fresh Water.
Do I need to sand it a little bit before painting too?
Thanks for any help!
shaunlaf
The bottom of the pontoons were painted in this special blue paint and it's chipped in some areas and needs touch up in other areas. The guy I bought it off of told me it was an expensive paint and that it would need some work soon, but I don't know what to get...
any help?
tallcanadian
A fiberglass pontoon and a fiberglass boat, same thing. Bottom paint, I'm sure, would suffice. I use Interlux products myself and it shouldn't be that expensive. Good luck.
thrillhouse700
Yes to the sanding, if you don't prep it properly it will just flake off. We had some extra super expensive epoxy primer and perfection paint and we rolled it onto our crappy trailer fenders with no prep just acetone. Yesterday I hit it with the steering cable and it took a big flake off.......
Sorry but Im not sure what kind of paint to use on a pontoon..........
shaunlaf
Ok, so I'd love as much detail as I can get on here...
Should I use a heavy grit and do some extensive sanding on the flaked trouble areas....
Also, do I need to do a light sand on the entire areas that I plan to paint? What about a primer? or will the light sand take care of it?
bitterboater
Well shaun is memory serves.... the paint can should have instructions regarding proper prep. Otherwise, the search function at the top will give a great many threads where painting was done as well as prep work, and painting technique.
drewpster
Well a basic prep plan for all paints would include getting the area to be painted as clean as possible. Any surface contamination is going to hinder the paint's ability to bond to the surface. To clean it start by doing a regular wash with soap. Use a good cleaner that will leave as little surface residue as possible. Rinse the area with clean water more than you think you need to.
TSP and water is a good start. (trisodium phosphate from the home center)
Next you need to continue cleaning using plenty of clean rags and a strong solvent. The solvent you use can be dictated by the paint you choose. MEK (methyl ethyl ketone) is a good slow evaporating solvent. Use the wipe on-wipe off method with two rags, one wet, one dry. Change your rags often. Lacquer thinner is another good choice.
Now it is time to do any sanding and repairs that are needed. If you are working on a relatively smooth surface a light sanding with a fine grit will do the job. The idea is to clean the surface, no necessarily get it smooth at this stage. While sanding perform a complete inspection of the surface. Follow the sanding with another wipe down with solvent to further clean the surface and remove the sanding residue. (320-400 grit by hand 220-320 power)
At this point you will have a good idea of any repairs that need to be done. Depending on the paint you use, bottom paint is relatively thick. If you want the surface to appear completely pristine and smooth it is necessary to sand the painted area smooth before applying any primer or paint. Start smooth, end smooth. Any chipped areas will need to be feather edged. Feather edging is the process of sanding the edge of a raised area until it tapers out removing any edge you can feel with your fingertips. If it feels smooth it will look smooth. Always follow any sanding you do with a solvent wash to keep the surface clean.
The next steps are largely dictated by the paint that you decide to use. To choose the right paint you need to ask yourself what you want the paint to do. Is it above or below the water line? Do you want a slick shiny look, or is the paint going to serve as a antifoulant? What color do you want? There are a ton of bottom paints on the market that promise everything from forming a slick surface that makes your boat run faster, to magic compounds that keep growth from fouling your hull. (in your case toons) Do some research and look at what is out there. I am sure there is a paint to suit your needs.
Most of all be thorough, and have fun doing it!
