rickasbury
Master Chief Petty Officer
Thread starter- Joined
- Jul 13, 2011
- 895
So, the disadvantage of taking something apart and so long in getting it back together- I do bag/label in excess but there is some stuff that I just tell myself I'll remember where that goes. That just never works that way does it? I just about have the transom assembly back together and putting the bell housing back on. When I did the bellows in round 1 of this project, I had lost one little part that I'm determined will put back together properly. So, on the pivot pins, in between the gimbal ring and the bell housing there is a little washer so you don't have metal on metal contact. When I lost the one side, I figured I would always be able to pull that pin out and put the washer in there once I tested the boat- I was so not confident the bellows was my leak and it wasn't so was on to round II of tearing out the motor and transom assembly. So, I had what I thought was one of the parts and when I ordered all my other parts, ordered one. "They" did not match but I thought no big deal, must have been updated since 2006. I can't get this one in there, it is just to thick and much thicker than the one I ordered.
It is a nylon type material, maybe a little more than 1/32" thick. I'm not even sure at this point if it goes to the boat. It is not one of the washers on the engine mount bolts as I have those bagged with all the other bolts for the transom assembly inner bolts.....any idea where this goes? I guess I will order another one like I ordered but now I'm puzzled that if this is not one of them, where did the one go that I did have if that makes sense? Weird! I'm going to go look at parts but I would have thought they would have come in a set of two anyway....
