What's Its?
joey nathan
Anyone ever seen the likes of this? Found it in the boat whilst removing/replacing carpet and upholstery for an upgrade.
Bigger hole is threaded, smaller is not thru...
Bt Doctur
Re: What's Its?
might be a type of locking device similiar to the OMC shift cable adjustment.Threads on to make/set and adjustment and the small hole accepts a both to hold it in place.
Don S
Re: What's Its?
http://www.iboats.com/Fulton-Traile...18797989--session_id.489584521--view_id.38148
artificialreef
Re: What's Its?
Are those things worth using? We get alot of trailer thefts here in Fla. That would blow coming back to the ramp and find your trailer gone.
theBrownskull
Re: What's Its?
They are worth it. If a thief cuts that off to take the trailer at least it makes them work for it.
H20Rat
Re: What's Its?
just have to use a locking drawback and a ball that has a weld bead on it. (well, at least a drawback lock, otherwise you aren't even slowing anyone down.)
roscoe
Re: What's Its?
I don't have to run faster than the bear, just faster than you.
I don't need to make my trailer theft proof, just harder to steal than yours is.
