what type of engine was in my boat
Kjeremy2
i have a 1990 sunbird corsair 175 stinger. i have searched the internet high and low tried to call different boat dealers and nobody can help me. i need to know what type of engine was in this boat when it was manufactured. i want to restore this boat during the winter months and have it on the water by summer :D i hope someone can at least give me a direction to look in. thanks in advance
Kjeremy2
Re: what type of engine was in my boat
im sorry if this was posted in the wrong are i wasn't sure where to post since it kind of is and isn't a repair question.
JB
Sounds like an I/O to me, Jeremy. I will move it there for you.
post a pic of the hole in the transom. most likely it was a 3.0 liter with OMC drive
Don S
Post a picture of the instruments and throttle control. That will help ID between Merc and OMC both of which use that cutout.
Your best bet would to be to start looking for a donor boat with a good Merc motor and drive and put in it. No reason to go looking for OMC, they went out of business in 98 and people are trying to get rid of them.
based on the outline left by the old transom shield, you had an OMC drive. as Don stated, easy to switch to Mercruiser since the holes are the same.
this begs another question. on a 22 year old boat, why did they remove the drive in the first place? I suspect the drive was salvaged. if that is the case, then you most likely have bad stringers and floor as well.
Kjeremy2
this boat was a repo that the guy before me bought at an auction and the reason that we came up with was to sell the motor and stern drive to pay off the loan so it wouldn't hinder there credit but the floor is solid and i'm not sure what you mean by stringers.
boat photo 4.jpgboat photo 5.jpgboat photo 1.jpgboat photo 2.jpgboat photo 6.jpg
Levinz11
Same remote control as my old boat. It had an OMC engine/drive.
Post some pics of the whole boat. You'll get lots of good advice on whether it is even worth it to re-power.
Kjeremy2
here is the rest of the boat
hope you really love the boat. its going to cost more to repop the boat than buying one you can drop in the water today.
Kjeremy2
i have another boat i just would like to restore this one and sell it or maybe sell the other one. i got this for free i just had to buy the trailer that is was sitting on
Ayuh,.... It's a Sunbird,...
Nobody's gonna want buy it for Real money, as it wasn't but barely worth any Real money the day it was built....
It'll cost ya up to 10 Grand to put it together, 'n the Best you'll get for it would be Under 1/2 that...
If yer gonna rebuild/ refit old hulls, ya gotta start with a "Classic", that somebody's gonna wanta Buy, for Good Money...
Not a Sunbird, or Bayliner...
Btw,... Stringers are the framework that holds a hull together,...
I'm Bettin' the 1s in that boat are Rotten...
Kjeremy2
i put this boat in the water to make sure it floats before i took on the responsibility so if the stringers were rotten then it would have taken on water which is didn't correct??
Don S
Not necessarily, you can have rotten stringers, rotten transom, rotten decks and never take on a drop of water ........ just sitting there static.
Get up on plane and see what happens. Just sitting it in the water is a non test.
Kjeremy2
well to do that i would have to put a drive in this boat. i don't wanna dump a lot of money into this just to have it sink on me is there another way to check?? and for this boat does anyone know the mercruiser replacement???
Ayuh,.... 3.0l/ Alpha....
For Hull questions, ya oughta head on down to the Restoration forum,...
Down there, ya can learn How to access a hull for rebuildin'....
Don S
You said you put the boat in the water and it didn't leak, I didn't say to do it now :facepalm: I just said it was a non-test by just putting it in the water.
That goes back to wondering what was in it before. We know it was an OMC, but no clue if it was a 3.0 or 4.3 so how can we tell you what the replacement would be.
Did the old motor mounts sit on the stringers or a front mount. I can't tell from sitting here. That would give you a hint at what the OEM engine was.
Kjeremy2
from looking at the bolts i'm guessing it was a front mount.
Don S
If it had a front mount that narrows it down to the Ford 2.3L engine or the GM 3.0L engine.
