What product for restoring the gel coat?????
Woodonglass
Honorary Supreme Mariner
Re: What product for restoring the gel coat?????
The 3m works really well but I would recommend using a VS Polisher to apply it. As bad as your Oxidation is it would take a lot of Elbow grease to bring her back to life. The polisher would make is a lot easier. Make sure to wask her really well first with something like TSP. Tri Sodium Phosphate. You can buy it @ Lowe's
Streffpilot
Ok, thanks, I have actually cleaned the hull so it looks much better than that right now, but I will definitely use your suggestion to clean any of the imperfections out.
Is there any way to remove the residue or whatever From where the stickers were??? Sanding???? I know nothing about gel coats so I'm asking so I don't screw it up, because believe it or not, there isn't a single crack :D
Streffpilot
It's in storage so no pics. Maybe I'll go visit her today :D
Yacht Dr.
You could try some acetone for the adhesive.
Gelcoat is kinda hard to screw up. You could "burn" it with a polisher .. but you would almost have to do it intentialy. The edges are where you have to be kinda careful.
YD.
Streffpilot
Thanks, Yacht Dr. This was one of those "free" boats, also my first, so it is a learning experience!!! Thankfully, the stringers and transom were good and solid. The rest.......well it's in a dumpster somewhere.
I will try the acetone once the weather breaks (live in Wisconsin...)
Yacht Dr.
Nice "Free boat" :) ..
If you can heat the adhesive up a bit with a hair dryer .. then acetone.
3m makes stuff called "adhesive remover" comes in a spray or just a qt. can. It works well mate.
Heat is a good thing when using these products :D ..
YD.
