12Footer
Thread starter- Joined
- Mar 25, 2001
- 8,217
I got a call from a friend of a friend,for whom,I rigged a boat out. It's a 16ft john with a Merc 20HP on it.<br />I rigged his steering and got his motor running fairly well,but it still had carb issues (needed a set of new gaskets from cleaning). He explained that he would install a carb kit in the clean carb before taking it out. So fine, 3 months later (Saturday), he calls me...."Hay, I'm a few minutes from your house. Can you look at this engine? It died and wont restart.", he said.<br />I replied it was no problem,I was home anyway,and would pull the other boat outta the driveway.<br />Well,he backed it in,and I went to werk on it. I removed the carb,and removed the bowl.<br />Then the float. NO NEEDLE VALVE. Kinda won't run without one. So,he gave me some green to buy a kit with,and left the boat. While I'm out there fooling with it some, I looked at the prop,and it is bent-up like a raviolli noodle. I turned the prop with my finger, and noticed a grosely bent prop shaft.<br />I don't know if i want to put this guy back on the water. Jiminee!!!
