vwbugman69
- Jul 11, 2011
- 116
I plan on reinstalling my garboard drain plug because the plug would shift when tightening and one of the screws could not be tightened.
My plan to do this is the following:
1) Fill in existing holes w/ Epoxy
2) Rotate Garboard drain 45 degrees
3) Seal Garboard drain & new holes w/ 4200
4) Install screws
Is this the best approach to use? Also, what "Epoxy" should I use to fill the existing screw holes.
Thank you for your replies.
4) Install screws
