Water pump install
Gradywhite3535
I removed the lower unit today to get to the water pump. When I took off the water pump housing I couldn't get off the collar that was under the housing. How do I get it off? Thanks a lot guys, I have pics so you can see what I'm talking about. Thanks
N1NE1
Re: Water pump install
I use a flat-head on top of another screw driver like a sea saw to get a little leverage under it then just kept working my way around.Some wd-40 also doesn't hurt.
robert graham
I believe that the removal of that interference fit collar causes damage to it and it should be replaced with a new one during pump replacement....
Gradywhite3535
Is the impeller I have good enough to get by for this year? It doesn't seem to bad to me but I'm a rookie lol.thanks guys for the reponse
N1NE1
It looks fine but 80% of the work is done.Your choice if you want to give up.
Pas Bon
Nothing looks wrong with it but if it were me...I'd change it. You have all broken down so why not? That way you have a new one in there and won't have to worry far a couple of years perhaps. Just make sure you install it correctly so the rotation is in the right direction.
staydry
Kinda looks like the collar has separated from the impeller....if so...a wood chisel will cut that collar and impeller off with just a couple of whacks....GL
