Re: Water logged foam... best way to dry out
Ok, I knew my comment about reselling the boat would get a bunch of you all wound up. Fact is, I purchased it cheap and knew it had issues, its just been one after another w/the motor and now everyone on here has got me thinking the damn hull is gonna break in two next time out!!! This is what I've come to realize since buying the boat 5 months ago. The previous owner trailered it w/o straps from miami to tampa and a wheel on the trailer flew off. the boat hull cracked above both wheels, where the bottom meets the sides, about a foot long on both sides. He did an OK repair job, which began to fail right after i purchased it, this began letting water in the middle section. I repaired the cracks, and now water only gets in there if it rains hard while we are out on it. I have resealed the port holes, and found other drill/mount holes in the floor that need to be filled. the water intrusion seems to have been a problem for about a year, and since I've owned it i syphon/wet vac all the water out when i get home, if it needs it. I'm a full time student, live in an apt, and can't take on a huge rebuild right now, maybe in 2 years. The floor doesn't have any soft spots, transom is solid. The bottom of the hull is scraped up and has chips in the gelcoat along the stringers. I certainly wouldn't be able to resell it as "good" condition, but for the price range one may find john boats, a rough center console with a few issues isn't too bad a deal. I'm gonna keep it for awhile, it's been a learning experience, and you are right, there is satisfaction from knowing you fixed something. I get pleasure from opening the hatch and seeing that water isn't leaking into the middle area. I'm not overly worried that my stringers are rotten and the hull garbage. I believe this boat will last me until i can afford a better one. I use this forum for its intended purpose: a source of FREE information. You guys can beat me up all you want, i've got thick skin, i can take it
