Water leaking
Boomoo
I don’t know if I have the right one . But here goes 90 to sea Ray 23 foot just had all new bellows put in I have a water leak water still coming in my boat at the rate of a gallon every 45 minutes it does it when the engine is not running too , I’m just sitting in the water so it’s not leaking from the motor I checked all the hoses I see nothing dripping anywhere I do have through the hull depth finder but I can’t find nothing there any help would be great
Grub54891
Check the gasket on the bottom of the gimble housing, where the trim lines hook up. I had the same problem and found that gasket torn. Other than that, it could be coming from anywhere. A phone on a selfi stick will allow you to get pictures and video in places you can't see.
Toyelectroman
I had to buy a cheap bore scope camera off of amazon to find my leak. Ended up it was leaking at the transom plate due to a rotted transom. Hope yours is not leaking for the same reason
Boomoo
Might be y pipe but going to check the lines gasket thanks
Boomoo
With me luck I’ll take the 2 bolts out and one will break lol
you may want to look at link 14 in its entirety
https://forums.iboats.com/forum/boa...r/295740-how-to-s-and-other-great-information
Boomoo
Well found it , filled the boat up with water 💦 and the new shift cable boot leaking bad up by the clamp ., going to loosen the clamp and try to push the boot on a little bit further and then tighten the clamp down again if that doesn’t work more than likely the new boot has a rip in it
