Water leaking from Impeller housing
clearbluewater
3.0 GLP-E
Water seems to be leaking from this hole under the impeller housing
It was leaking so I decided to change the impeller and the oring but looks to still be leaking
What could be causing this and how to fix. Thanks.
Andrew W
More than likely the seal is going bad. Noticed mine was slowly dripping this weekend as well. Going to rebuild it with a new bearing and seal.
BRICH1260
The circular spring shaft seal on the back side of the pump needs to be replaced.
Rebuild kits and replacement pumps are inexpensive if you look for the Johnson pump directly. Sherwood also has the same pump.
BRICH1260
Technically its the top right circular piece that went bad but it is common to replace all the pieces seen while you have it apart.
