Warning buzzer
davisg
45 Merc. Jet, continuous buzzer going off when the key is turned to the on position while sitting the garage.
When you disconnect the 2 blue wires that come from the sensor in the bottom of the oil tank the buzzer stops.
Replaced the sensor with a new one, buzzer still sounds????
Any ideas is there something I need to reset or is there something else???
Thanks
Re: Warning buzzer
Magnet fell off the float and is sitting on the bottom of the tank triggering the buzzer. Drain the tank and check for the magnet.
davisg
Re: Warning buzzer
Thanks that was the problem, new tank on its way. Why does this happen?
