TOHATSU GURU
- Jul 22, 2004
- 6,164
Re: WallyWorld SuperTech 2-Cycle Oil
Forgive my deversion from the orginal question, but the primary reason that DFI engines require synthetics or semi-synthetics has to do with the atomizing of the oil droplets as they are injected into the engine. Both Mercury and OMC learned the hardway that regular TC-3 formed larger droplets as it was being sprayed causing incomplete burning of the oil, causing premature fouling of the spark plugs, causing really ticked off people and lawsuits.( That's in addition to some really bad intial design flaws) Synthetics and semi-synthetics atomize better,are more combustible and do not foul out plugs anywhere near as fast. At onetime( a very long time ago) I used to tell people that the only oil they should not use was Quaker State. That was due to the high ash content. Today I really do not think that there is a bad oil being marketed. While one oil or another may provide an additional slicker or be a little less refined it is in and of itself not an engine killer.
