Re: Vortec Test
If rust from manifold or riser falls into chamber it can lodge under valves, it can crack valves, it can crack heads if the lodging point is between the valves, if caught under an intake valve it surely will make it backfire. I continued to use mine until both heads needed work. I did go with glm alu manifolds and they were easy to install. Two seasons with them,"great"
