Re: Volvo Penta AQ270 noise when turning
Rented a TipTow towable engine hoist with the long legs and arms. It barely cleared the side of the boat, but the engine is out and the bellhousing is off. It is a "special" Waukesha (PCM) version, not the Volvo Penta variety. But I was able to find numbers on the two bearings inside.
Closet to the engine (inside the boat) is an SKF 6007 (d=35, D=62, B=14) and the aft end (outside the boat, nearest the u-joints) is an SKF 006 (d=30, D=55, B=13). So far, I haven't found any in stock locally.
I did get both bellows ($72 each) and some o-rings at my local Penta dealer (30 miles away is not exactly 'local') who steered way around my PCM parts but was willing to help with the true Volvo parts. They wanted $58 for a single U-joint (I passed, having seen Sierra units for almost half that elsewhere).
I hope I can find the bearings and grease seals tomorrow so I can button up the bellhousing with the new PDS bearings/seals so I can put the engine back in and return the engine hoist within my 24 hour rental.
More to come - but at least I have all the bad parts out!
Later,
Jerry
