mguidry629
Thread starter- Joined
- Sep 19, 2011
- 53
I can't really verify what kind of ignition system came factory on this Mercruiser 5.7, but I think it was points. What I found on the boat when I inherited it was an automotive HEI unit. And it ran great, but I wanted a marine set up for safety reasons and the Delco EST was recommended on here (so far I regret that decision).
#1 - Is there any reason you can't use a dial back timing light on this ignition?
#2 - My shift interrupt switch has 12V when in neutrel. When switch is activited it kills the 12V. I was told the Delco EST works just the opposite...should be 0V at idle and 12V when activated as the 12V is what momentarily kills the ignition. Is this correct? If so, how do I wire the switch to correct this?
Now to the major issue I'm having. I have everything wired up correctly to set timing. I crank engine without the harness that includes the shunt. Set timing by ear and let it idle (timing light showed about 12*. Instructions say to install shunt harness and connect black wire to 12V and set timing to 1* BTDC. Done. Then I remove the 12V from the black wire and cut the white wire loop. Nothing changes. Advance stays at 1* BTDC. Then I rev up to about 1800 (runs like crap) and check timing and it is MORE THAN 60* ADVANCED.
So I call the vendor that sold me the Delco EST and he says you can't use a dial timing light. So I go get a check timing light and same thing.
When you disconnect the 12V from the black wire and cut the loop, the timing should jump up a few degrees at idle, correct?
This has to be a bad module right? What else could be going wrong here?
