ftlee20723
Thread starter- Joined
- Sep 19, 2009
- 1
I picked up a new (08) Trophy 2206 Dual-Console today. I took it on a 2-Hour ride and when I arrived back at my marina and pulled the drain plug out there was A LOT of water in the bildge.
The owner's manual supplement states that:
Are there supposed to be drain plugs in:
1. Port Cockpit Drain?
2. Aft Livewell Drain?
3. Garboard Drain (Yes)
4. Starboard Cockpit Drain?
5. Utility Center Sink Drain?
6. Starboard Forward Fishbox Drain?
7. Port Forward Fishbox Drain?
Where do the drain plugs go? On the outside of the boat or, in the fishbox itself? I'm pretty sure I saw a bag of plugs on the boat but, I don't know where they go.
And last, where is the seacock for the livewell?
Thanks,
Frank
Depending on the type of boat you have, you may have underwater fittings that need drain plugs. Garboard drain plugs and fishbox drain plugs need to be in place before the boat goes into the water. Any fitting that will be underwater needs to be plugged or the seacock needs to be closed.
Thanks,
Frank
