Trophy 2002 with 2 stroke 150hp Mercury Blue Water
Tregaskis
Just bought this very clean 1999 Trophy 2002 Walkaround...the engine has even compression (115-120lbs), runs great and seems to have plenty of torque...the boat came with a Michigan 15x17 3 blade and will only turn it at 5000 rpm at full throttle, 2 people, 3/4 fuel...I changed the prop to a Turning Point 15 x15 4 blade (with relief holes)...this prop really helped the planning time and lowered the rpms necessary to stay on plane but it too will only turn 5000 rpm with same load and trimmed up just short of ventilation...this shows 33.5 mph on the gps...since this engine is supposed to turn up to 5600, I suppose my question goes out to owners of like units...is this normal performance or ?????
JohnNJ
No Title
Congrats on the new boat! I have a 2001year 2002 with a 150 Mercury Saltwater. The compression on mine this past summer was Port side T-115 M-116 B-115 Starboard side T-120 M-121 B-121. The factory prop was a Mercury 15 X 17, I changed over to a SS Michigan Wheel a few summers ago which I think is the same size. I will check and let you know. I ran the factory prop early in the season last year while I had the SS cleaned up. The factory prop did allow me to get up close to the 5500 range, but the SS one is always around that 5000-5100. Not sure why. My top speed is max around 35, depending on load and gas.
Let me know if you have any other questions.
John
JohnNJ
No Title
This is the prop I am using now, but as I said I cannot get up around the 5500 - 5600 with it. 14 1/4 X 17
Tregaskis
Sounds like we are sort of in the same boat :).....thanks for the input. I am going to take the whale tale off that the previous owner put on and see if that makes a difference too. I don't like running a Merc in the bottom end of the rpm range...not sure how the newer ones handle it but I learned on the old ones that loved to burn pistons when they were lugged. Thanks for your help.
