Trolling problem
birdgod
I have a Boston whaler rage 14 which I convert to a fishing boat. Love it so far. The only problem I have with it is while fishing along the shore line with trolling motor. The back of the boat tent to swing left and right making it very hard to control..... I wonder if I add a homemake rudder at the back of the boat will help. Any one have this problem before. I need help.
Volphin
What is the trolling motor setup? Is it pedal operated? Does it rotate for direction?
poconojoe
If it's a transom mount trolling motor, you might get a lot of that, depending on the boat. That's why bow mount trolling motors are preferred. Bow mount pulls the boat, while transom mount pushes and the boat tends to wonder.
jrttoday
I used to take a piece of plywood and just clamp it to the side with visegrip clamps or C-clamp. It will swing up if it hits bottom etc Almost anything will do, but you need something back there without a motor.
Ayuh,..... Put the outboard back down, 'n use it,....
birdgod
Sorry, I am not clear about the boat. It is a jet boat so no outboard. And it is a 40 lbs trolling motor bow mount. I think the problem is that the jet boat is flat at the back.
