Transom trim on StarCraft 1970
Scuzzy71
I’m going to replace my transom on my StarCraft what are some other options or DIY ideas
Jimmy Starcraft
I have a 1973 ss that I will be doing the transom on. How did it go anything come up worth knowing before I get to mine? Thanks
MikeSchinlaub
Let's of transom threads here. Look them up and do some reading. Some quick points though, you will want plenty of ppe. Tyvek suit, P100 respirator (preferably full face), disposable gloves, safety glasses, organic vapor filters for the respirator. It will be extremely itchy, messy, and fumey.
And feel free to start your own thread if you want.
redneck joe
mike it appears that is an aluminum. OP, please specify but same as he said - lots there to look at. Do you know the model and/or can you pls post a pic of the whole boat so we can help you with that.
there are lots of 'hacks' out there but wod, properly done, is your best bet. It appears the aluminum top cap has been lost and it was just painted over so whatever you do when you are done fix that.
matt167
Fiberglass StarCraft = itchy mess. Aluminum StarCraft= relatively easy. Remove trim and end caps, un bolt/ un screw everything. Remove drains and plug bung. Pull old out, trace, cut, replicate new. Seal, install and reverse process.
