Transom soaked - Plan of attack - Splashed
TrybalRage
Had a really productive weekend. Hardware installed - new scuppers (boy did I make a mess with the 4200) from TH Marine, tie down/lifting rings installed, drain plug, stainless thru hull for bilge pump drain, and more.
Also not pictured - new 2AWG battery cable run from console to relocate battery there, Perko switch installed so I'm ready for a second if desired, cleaned up some sketchy connectors and added heat shrink to those spots.
Finally - motor hung yesterday!
I ordered a new bilge pump rather than install the original 16 year old one, so that's the last thing that needs to go in. Hoping to splash this week.
TrybalRage
I put some primer on the inside of the bilge as well. Should probably top it with some BilgeKote.
Outside you can see where I stopped the paint.
TrybalRage
Splashed! Finally got in the water! Had a little trouble getting the 2-stroke to stay running at first, I think the gas is a bit stale. Going to drain it out and use it for other stuff, and refill with fresh.
But once it cleared some stuff out at full throttle, it ran pretty good! All in all a good day.
sphelps
Congratulations on the splash !!! Well done and looks ready for some fishin !!
TrybalRage
I caught absolutely nothing that day, my buddy who's being helping out this whole time caught a bunch of catfish, nothing else was biting. Still a good day!
