Transom repair
condorsun
Hi I am new to iboats and have been using the resto section for info for my transom repair as this is the first repair job I have attempted. I have found some great info so I have signed up to show some picture. One tip was how to start "get the angle grinder out and go for it" .The boat is a 1975 Condor sundance I have had it for 16 years and have had a great time fishing and skiing before retiring it for last 10 years. Last summer I decided if the motor starts, a Chrysler 105 I will repair that rotten transom and it ran great. So here are some pics.First a before pics
I remove the deck just past the well.Made a huge chisle and away I went.
[Made a pattern and cut out the new transom
Fit and glass back in with lots of clamps.
Now to glass the inside
And thats it so far Cheers.
condorsun
Re: Transom repair
Can some one help me with this.I am going to flow coat the the transom but before i finish the floor should i flow coat below the floor first.
Friscoboater
Re: Transom repair
For the pictures it looks like the tabbing does not go very far onto the hull at the bottom. It should go about 6 inches out.I might be missing it. Also you need to grind all paint off (the red) before putting glass on it, or it will not stick.
Woodonglass
Honorary Supreme Mariner
Re: Transom repair
Good CATCH frisco!!! You ARE exactly correct.
condorsun
Re: Transom repair
The tabbing does look that way as the photo was taken before it went off but it does go under further and now I have take your advice thanks.
The flowcoat I used is a non air inhibited polyester coating which i applied to the hull.I mix a red pigmet for the transom.The red is not paint.
When i fit the splash well you wont see the back.
condorsun
Re: Transom repair
Summer in Australia will be here soon so I will try and finish the boat. I have started painting the under coat.
condorsun
Re: Transom repair
I finished the boat about last year. Hear are some pictures of the tim and final fittings.
Made some new seats
