I have a 1986 Mon Ark that I picked for next to nothing. The motor (inboard 3.0) and outdrive are OMC and seem to run very well. The transom is shot...I mean there is not a piece of good wood left in it.<br /><br />I cut the top off the transom (which surprisingly was pretty poorly made...fiberglass layer was paper thin under the top of the rear of the boat) and have started removing the wood...or should I say splinters.<br /><br />Am I crazy to think about cutting the outer fiberglass off the transom to really get in there and make my repairs? I thought if I cut in from the edge 2-3 inches that would give me a pretty good support to re-fiberglass the rear back on. I would go back with either 2 layers of 3/4 or 4 layers of 3/8 marine plywood, fiberglassed in between, and then the outer layer. I would of course have to grind the edges and re-appply. <br /><br />I can do it from the top, but the job would be a million times easier if I were to cut the back. What problems am I asking for by doing this? I do have some fiberglassing (automotive) experience FWIW.<br /><br />Thanks in advance!!! <br />Email: jmwj03@hotmail.com
