agallant80
 - Oct 25, 2010
 - 2,328
Anyone out there have an EcoBoost? Any issues ? How does it pull?
 If you are going to slap a 6 cylinder anything in a truck and use MPG's as a selling point, it better give me 30% better mileage over the v8 competition before I write a $40,000 check.
The Galactica, with the V-10 Triton guzzles gas like it's .29 a gallon. But she does fine with a 2,100 pound camper in the back, and a 4,000 pound plus boat and trailer behind her.
Love the name Galactica.
There was an article in motortrend or one of the major car magazines about a year ago that did a test comparing a few different f150 models. They stated the new 5.0 was a better tow engine overall. If I remember correctly the V8 got better mileage while towing which makes since. Little engine has to work harder so the turbos wind up more sucking in more fuel.
I read some forums about the ecoboost that seemed to follow the write up. Basically average mileage wasn't any better than the V8. Highway was good but overall people were stating about 17mpg. does not impress me. not going to make me spend a ton of cash to save 1-2 mpg.
Also, can't imagine what the cost would be to replace one of those turbos when, not if, the go.
modern turbos are a world apart from the old type and now with better oils and redesigned cooling of the turbos especially when the engine is shut off the turbo should be good for a few hundred thousand miles. old turbos liked to cook when the engine was turned off and the oil would bake on the shaft causing all sorts of problems.
Have you ever wondered why ford doesnt call it a turbo
I just don't believe a turbo is necessary. The 5.0 is a simpler design with pretty close to the same mileage overall. There really isn't a perfect engine design since the whole problem is the weight and aerodynamics of a truck. If the companies would learn and go back a little and lighten up the trucks and stop making them so tall we would be better off.. Man i am 6'1" and can barely reach into the bed of my truck... There is no need for an f150 to be able to tow 10k or whatever it can do just to go the grocery store. step up to a f250 if you need the capacity. they needed to redesign the smaller trucks rather than discontinue them as well. (man I sound like an old crotchety man)
