to weld or leave alone
a6n6d6y
I bought an 83 Chris Craft 230 Scorpian w/260 merc (sn#6261027), out drive has a crack by the prop, from what I have read it was probably caused by corosion between the lock ring/bearing retainer and the case
I have preasure tested it and it held 30 psi for two days, as far as I can tell the drive is good except for the crack.
I was thinking about drilling the lock ring and using as pressure washer to remove as much crap as possible from inbetween the retainer and case, installing a new lock ring and welding up the crack, what do you folks think ?
http://home.comcast.net/~a6n6d6y/andy/outdrive1.jpg
http://home.comcast.net/~a6n6d6y/andy/outdrive2.jpg
thanks for looking
andy
Re: to weld or leave alone
thanks for looking
andy
Ayuh,..... Run it til she pukes, 'n then Replace it....
Corroded aluminum don't weld so well,... It tends to be porous, 'n leaks all by itself.....
mercs4mark
i say run it.....not leaking run it and keep an eye out for a replacement
ENSIGN
That spanner nut is in there tighter than you think. Since the crack is away form the gear case LEAVE IT ALONE! You'll do more damage just trying to get it loose.
ohio river rat in KY
what about drilling a hole where the crack stops to keep it from cracking more? or would that be advised?
Jmunk
JB Weld, cheap and works darn good on something like that.
