Yacht Dr.
- Feb 26, 2005
- 5,581
Re: Tips from my shop
The blue Nitrile gloves are good for mechs..not glass guys ( they are too combersome and hard to get on and off quickly IMO
Put baby powder in your suit and your good to go..wrap good and your not needing Duct tape to peel glass off you.
I would be carefull about putting solvent rags in any can ( they can self ignight ( Fire ! ) .. I dont know of Department of Tranportaion ( DOT ) regs. Docrodgr has a point about Rags..
You should never open a can of anything toxic without 2nd or third party looking after you...
YD.
I am a fan of Nitrile Gloves which are tougher then latex and yes get the powdered ones.
The other thing I always tend to keep around is a first aid kit. You never get cut when you have one around but, when one is missing.....you always seem to get cut or pick up a respectable splinter!
Duct tape, it will help remove fiberglass from your skin, not all of it but it makes a huge difference. As a heating and ac guy I used to spend a lot of time with the stuff. simply roll a wrap or two around your hand backwards so the sticky side is facing out and pat down the effected area.
OK... A couple of my tricks/requirements:
A somewhat stripped screw head or screw that is really tight can be backed out by spitting on the end of the screwdriver or bit and dipping it in Comet bathtub scrubbing powder.
A good rag can is a must. It should be a flammable rag can used in commercial shops.
Before using a chemical check the NIOSH website for which gloves, filters, etc. are compatible. http://www.cdc.gov/niosh/npg/
Get a DOT approved metal gas can for spare gas. And a nice big fire extinguisher.
There is no adapter needed that cannot be fabricated for 10 bucks in plumbing fittings at the hardware store.
Before working on wiring check your crimpers to make sure they crimp correctly: Take a piece of wire and crimp a ring on it, screw to your workbench, wrap wire around a screwdriver and pull... hard. If it holds you are good to go.
Welding sparks fly farther than you think, and stay hot longer than you think.
Use foam inserts in a tool box with cutouts that fit each tool. When done working, check that all tools are back in their spots so you don't destroy your engine when you start it.
First aid kits and fire extinguishers are a must. If working alone, so is a cell phone.
YD.
