mattevans24
Thread starter- Joined
- Feb 22, 2012
- 11
I am fixing up a 1987 Blue Fin 17' aluminum boat. I am through the tear down stage and its time to repair then rebuild. There are about 30 tiny holes in the bottom of the boat. I don't know what may have caused this. I did a punch test with a screwdriver and aluminum around it isnt brittle at all. They are all in the center, from where the poured foam starts, to the transom.
Anyhow, I am going to drill each of them out and use blind rivets, at the recommendation of jigngrub. After sizing up the holes, 3/16 seems like the appropriate size.
My Question is what length rivet do I need? I have never worked with rivets and I don't particularly know the thickness of the aluminum. It is only going through the aluminum in the hull, it won't be traveling through anything else. Below are some photos. The dark photo is one from under the boat and I turned off the lights in the garage and placed a light in the boat.
Anyone else have this problem with their aluminum hull? Any ideas on how the holes were formed?
Thanks!
Thanks!
