- Jul 23, 2011
- 53,109
Scott, other than that it works good for you? I just go thru vinyl and into the plywood or plastic Thanks for the reply.
works great. shot everything from 1/4" staples thru the thin backing for the dash pads to 1/2" staples on the trailer carpet. been thru about 7000 staples so far.
shot into plywood, plywood with epoxy, plywood with fiberglass, PVC foam board and the bunks on the trailer, which I believe are treated yellow pine.
at 120 psi, you will shoot the staples directly thru the vinyl cutting a nice long slit. so back the pressure down to the 80-100 psi range
