Thru Hull type and sizing
fdmsiv
I am planning to add a thru hull fitting to my boat. I plan on having a livewell, baitwell, and a washdown pump connected to the thru hull. What diameter thru hull do I need for a 5-6 gpm washdown pump?
I have seen 2 types of thru hulls in the stores. A disk shaped and a wedge shaped. I really like the wedge shape because it has a screen on it and I think it looks better. Is there an advantage or disadvantage to using a wedge shape instead of a disk shaped thru hull?
Lastly, where is the best location (obviously under the WL) for the fitting? I was thinking in the aft 1/3 or so of the boat. Is this a good assumption?
dingbat
Re: Thru Hull type and sizing
I have 2 - 1" bronze scoop type intakes for my pumps. One for the WD and one for the bait well.
Dave Abrahamson
...and you thought "trailers and towing" would be the best forum to post this question because......??? ;)
(just bustin your .....stuff ;) )
fdmsiv
I get a little carried away with viewing too many tabs at once... I was starting to wonder why this thread wasn't showing up in the general boating forum:redface:
