redfury
- Jul 16, 2006
- 2,655
I think it's high time that we compile our experiences with the different paints out there and discuss what we like and don't like about them. What I'd like to see is some specifics beyond " I just like it", if you know what I mean
For those that roll and tip, what size roller, what kind of brush, plus general working conditions.
For those that spray, what type of gun, tip size and air pressure seemed to work best.
For those that have done both, pro's and con's to doing each type of painting.
Finally, discuss the properties of the paint you used. How well did it flow, was sagging an issue on vertical surfaces. Did it flash dry too fast, or stay wet too long. How well did it sand if you had to repair a run and is it a paint that can be touched up, or do you have to repaint an entire section to get it right. Is it a paint that should be left to pro's or can someone with almost zero experience get the hang of pretty easily.
For you body shop guys out there, give us some tips on proper prep, how to handle ourselves personally when dealing with the materials and setting up our paint booths ( if we even have one at all, or if it's just simply plastic sheeting hung up )
It's easy to think that a lot of this is common sense when you do it everyday as your job, but for the person whom has never picked up a paint gun, there are a lot of little nuances to anything that they aren't necessarily going to think about....help us out with them!
