Testing surge brakes
sailcal
How do I test the surge brakes on my boat trailer to see if they are working.
I can't tell if they are or aren't are actvating when I am towing the boat.
superbenk
Re: Testing surge brakes
You shouldn't feel the trailer pushing you when you put the brakes on. Shouldn't really feel much different than braking without the boat (you'll still feel it back there, but it shouldn't feel like it's pushing you).
Also, if you feel the brake discs or drums after some hard braking they should be hot (don't burn your fingers!).
arks
Testing is easy. I raise the trailer wheels off the ground, then put the ball mount into the coupler (not connected to the truck). Spin the trailer tires by hand and push DOWN on the ball mount. If the trailer brakes are working the wheels will stop!
superbenk
Ok, I like arks way better. More definitive answer.
bruceb58
That's how I tested mine as well until I got electric/hydraulic.
lncoop
You can also use a screwdriver to actuate them.
elkhunter338
Master Chief Petty Officer
You can also go to a hill and try backing up the hill and see if you feel resistance from the trailer brakes. I can sure tell mine are working when I back up a hill and forget to engage the back up solenoid.
marcoalza
Don't get too complicated.
Just try reversing and you should feel the brakes come on.
The action of the actuator will be the same as if youy were braking normally.
superbenk
Unless you have a reverse release solenoid wired into the system & no easy way to disconnect it.
Lakes84
I just put hydraulic brakes on a virgin (no brakes on it...ever) Florida tandem trailer that carries my 21 ft SportCraft yesterday. Took about 7 hours to do it myself.... fairly easy. Hardest part was connecting the hoses and bleeding all four wheels. I took it around my neighborhood to test the brakes and like others have said, I felt it back there, but it stopped easily. I tried different speeds and stopped quickly to see if they would work..( also checking for leaks). Better to test something like this on a quiet side street than in real traffic. I towed it in rush hour traffic this morning on I94, constant stop and go and the brakes worked perfectly. Safety first when dealing with brakes!!
See you on the lake
Joe
smokeonthewater
when I wanted to test mine I grabbed a couple pieces of 4x4 lumber and chocked behind the wheels... then back up.... rolls over w no prob=bad.... jams against wood and slides=good
