Temp Sending Unit
joey nathan
Has anyone retro-fitted their outboard with an aftermarket temp gauge? (Okay, dumb question, but...) Where can I safely drill/tap into the side of the intake for thermocouple/sender? Prefer to do this with intake manifold in place.
I have a '75 Evinrude 70HP 3 cylinder
Thanks in advance...
erikgreen
Re: Temp Sending Unit
Probably this will need to be moved to one of the outboard forums.
I'd suspect that wherever you drill you'll want the part off the motor, since otherwise little scraps of metal could get into the cooling system.
There are screw-on and strap on type temp sensors too, by the way.. there are kits for these at defender and other vendors.
Erik
