Tachometer Pole Setting for Yamaha 70hp?
branman1971
Anyone know what the correct tachometer pole setting is for a 2003 Yamaha 70hp 2-stroke motor? I was told 6pole position but think i might be getting false tach readings.
Barnacle_Bill
Re: Tachometer Pole Setting for Yamaha 70hp?
For that motor your tach should be set at 3P.
branman1971
Does it make sense that my tach only shows a 4, 6, 10 and 12 pole setting? No "3" to be found.
Barnacle_Bill
What kind of tach is it and model? If those numbers are for poles, then it should be set to 6. If there is a P after the number they are talking about pulses which in your case would be 3P.
branman1971
No, they spell out the word "pole"...So try the 6 pole setting? Ok...
Dunaruna
The setting for your motor is definitely 6 pole.
branman1971
Oh, and it's an older Faria gauge...
