Struck by Lightening, "Bud Lightnin' "
buffbenj
RESTORATION STORY STARTS ON POST #16...1987 Alpha one 3.0L trying to get it ready for the weekend, first time since purchase. Alot of renovation. Added fuel separator/filter. Starts on first try at idle, obviously with earmuffs on. Alternator seems to be charging, voltmeter increases from 13.1 to 15v with throttle to 1500rpm, but the alternator is smoking after a few min of running. Belt is tight, not slipping. Alternator is not original. There is a black wire and a purple wire which are capped off. Previous owner swears it was working last year. This is the first start since July 4, 2011. Certainly this cant be common. It is not newly painted, but I did use engine degreaser about a month ago to clean up the engine. Is it safe to take out on the lake?
tpenfield
Re: Alternator smoking
No it is not safe, because where there is smoke, there is fire (or soon to be fire). Fire in the engine compartment is a wicked bad thing.
It is important to fix the alternator problem if it is smoking.
that would be the magic electrical smoke. once it starts escaping, that is BAD
tomdinwv
Pull the alternator and pull it apart (or have it done) and see whats going on in that thing. You don't want your boat on the water til you know that alternator is working properly and it is not a fire hazard.
Ayuh,.... Alternators don't like washin' anymore that little boys do, either....
If yer washin' the motor, ya gotta bag the Alt, Dist, 'n the oil vents....
fmalott
X2!
jimh1626
Smoking is just as bad for that engine as it is for you.
mark1905
Yup. Sounds like she's toast. A new one from DB Electrical is pretty reasonable.. $69 for new 105A model. http://www.dbelectrical.com/c-7743-mercruiser.aspx
Although.. looks like no boat for the weekend. Lesson learned to make sure she's weekend ready every Monday.. :D
buffbenj
OK, starter/alternator repair shop said lightning strike last July probably hit the alternator and it's putting out AC current. Sure enough, regulator is bad. Got a single wire replacement marine alternator for $85. Hope it works-should be a good Sunday! Thanx to all who replied.
mark1905
Nice work... but ready by Sunday?? That's a 15 minute job!
Fishermark
OK, starter/alternator repair shop said lightning strike last July probably hit the alternator and ...
A lightning strike? Seriously? :confused: I cannot imagine lightning striking your boat and the only thing damaged is the regulator.
Glad you got it fixed... but lightning????
Ayuh,... I'd sooner think it's from gettin' it Wet, washin' the motor...
I ain't buyin' the Lightning strike either...
CoffeeHound
[/B]Matter of opinion !![/B] At least the "you's let the smoke out !!
When alternators smoke and let the smoke out , they are hot enough to cook anything around them, includining fuel lines ,water hoses and wireing!
UncleWillie
Once the Magic Blue Smoke gets out, the only way to fix it is to find and repair the leak,
then get a new can of Smoke and fill it back up. :rolleyes:
Sorry, I waited a long time for that one, and just couldn't resist! :eek:
buffbenj
Wasnt the only casuality from lightnin. Starter solenoid & up trim solenoid both blew, ignition switch fuse holder cooked, 1/2" hole in bow hull, below waterline. Seriously, lightnin'-apparently when it struck, it threw a gal sitting in the bow into the water, and knocked 2 grown men down from console to the stern. Apparently he jammed a screwdriver into the fuseholder, jumped the starter solenoid, and limped it back in. It did run (still does!) As for the alternator, maybe I did get it too wet during pressure washing, but I was fairly careful...lessons learned-gotta wrap it. Refurbished, single wire alternator is gem dandy! $85. All in all, Sunday was a GREAT maiden voyage-and remember I got this boat & trailer for $300!Maiden voyage 016.jpgMaiden voyage 018.jpgMaiden voyage 005.jpgMaiden voyage 006.jpg And yes, the name graphics on transom are pending: "Bud Lightnin""
buffbenj
So from the beginning, I saw this boat on a trailer in a neighbor's yard. '87 Corsair Sunbird. Now, I know from the forums that this was a low end manufacturer, but the 3L Alpha One caught my eye, so I gave $300 for it and started the restoration process.Orig starboard.jpgOrig floor.jpgOriginal bow.jpg. I went "all in" for a really low budget restoration, taking his word that it runs. Got about 100 hours labor in it, and an additional grand.
So, I removed carpet and the 2 seats, and he had made a fishing deck across the bow. Of course, I pictured bikinis rather than minnows across my bow, so I excavated the deck as well. Removed all the badly faded Teak wood. Fortunately, there are NO soft spots on the floor. Then I attacked the 1/2 inch lightning exit hole at the bow, below the water lineLightning hole.jpg. Got my order list together submitted to iboats-really saved me $$. Took 4 layers of fiberglass patching and sanding, followed by epoxy paint.Lightnin patched.jpg. Cleaned Teak with Gain and bleach with a brush, then about 5 coats of Teak oil, and it looks new again, yet not slick.
buffbenj
Pre-oilTeak.jpg Drained the 20 gal gas tank, then put a small fan on the inlet for days at a time, to dry it out completely. installed a new fuel filter/separator at the transom, btwn tank and fuel pump. Started organizing the wiring. Up trim solenoid and starter solenoid replaced.Orig trim motor.jpgFuse.jpg. Up trim switch was also blown. It was in pieces, built in to the Quicksilver handle. Throttle mess2.jpg I read where design was poor and twisting/fraying of these wires at the throttle was common, so I decided to move the new momentary toggle trim switch and the old trailer switch to a plate on the dash. Fabricated stainless steel plates for trim and one to replace the cracked plastic cover of the throttle handle, painted them white and black.
buffbenj
Plate.jpgShifterplan.jpgI had the stainless left over from building a house, it was a stove vent cover. Used heck out of a Dremel, Jigsaw, and even circular saw with SS cutting blade. Maiden voyage 004.jpgThrottle complete.jpgWhat about the throttle button, to rev in neutral? Well, it's broken and looks like I can get by without it.
buffbenj
Floor had alot of screw holes, so patched them with epoxy. Floor holes.jpgAnd for some reason, Corsair made these gutters at the stern, that collected water along the carpet line and man did I have to scrub the algae. Gutter.jpg Seemed to me that you want ALL water to drain to the bilge, so I got a gallon of Bondo and filled in these nasty little gutters.Gutter patched.jpg
buffbenj
87 Sunbird
87 Sunbird
Likewise, there was a fiberglass ledge up at the bow, and smoothed a little incline ramp with my trusty Bondo, so no tripping on Bud Lightnin"!Gutter filled.jpg Actually, getting the nasty, wet carpet out from under that fiberglass frame was a real nightmare! Interior bumper cushions didnt color match, were faded, and had metal washers & screws holding them on. Removed all of thatInterior.jpgOrig throttle.jpg, but I did salvage the foam since it is expensive! Washed each piece in a bleach detergent solution to kill the mold spores & mildew, then put them in a confined space with a dehumidifier for about 2 weeks. They are dry as a bone! and clean, too. Bleach kills everything. Used the rotten plywood underneath as templates and cut 1/4" plywood, painted with exterior paint I had left over. Looked at a few thousand internet pictures and decided on my color coordination. Indoor outdoor carpet, UV treated, Home Depot, $43 for 7x12. I know, marine carpet is best, but I can replace this (with labor) 4 times over for the price difference. I'll take my chances. Had some leftover flooring adhesive on hand. It works.
