markedenfield
- Oct 20, 2005
- 18
Re: Stringers
Greetings - Couldn't locate the how-to section.
I took a lousy photo of one of the stringers we shaped yesterday...we have the other side to do today. We decided to laminate two 3/4 inch ply together for them. Thought it would be stronger.
Decided to use the West System.
Do we take the deck all the way top the sides of the boat and laminate the deck to the sides? Since this boat will be used for skiing, tubing, wake boarding, the kids will be climbing aboard and shaking the water off like a dog. There is no transom plug to drain...only one plug midship and I suppose that is used to drain the oil. There was two bilge pumps and I'll replace those. However, should I cut several half circles where the deck meets the transom so the water can drop down and get sucked out?
The posicle sticks still have me a bit confused when you come right back and laminate the stringers to the hull. What is the purpose of the popsicle sticks.
Do I laminate the stringers to the transom?
Is it ok to break the full length of the transom at bulheads as long as I bond the two together nicely?
I wanted to keep as many screws out of the deck as possible. Is there a way to use cloth to hold it down to the stringers instead of screwing it?
That's it for now. It's brrrr cold outside so we'll have to give it a while before Mr. Sun heats things up.
