stringers help
Woodonglass
A gallon of resin will do about 4 sq yards of 1.5oz CSM. You'll have enuf
andrzej
thank u again
few ??
i redid the stringers as original
i glued down new floor as original with the mixing fibers and poly resin
as u could see on the pictures the new floor has round curve
the white round spot on the transom is the drain
should i seal the new floor from the boat bottom hull ? and install separate inspection plate in the floor just in case of bilge pump out ?
right now as i can see is :
seal the new floor with boat hull bottom completely
install bilge pomp in that place
to remove water from the deck
make new opening for the another bilge pump between deck and hull Thank u :)
i hope that u could understand what im asking :))
Woodonglass
Yes you should resin and glass both sides of your deck plywood. I'd recommend building a Closed in box for your bilge and leave it open for easy access.
andrzej
thank u
yes the plywood deck is resin with 1708 under
now im going to fillet the bilge area with poly resin and microfibers mix to make the closed as u said for the bilge then fiberglass over with 1708 then 1708 on the top of the deck
sorry i didnt reply sooner but im doing this outside with the generator and the weather was not so good lately
