proshine43
Thread starter- Joined
- Sep 5, 2010
- 161
hello all. i have a 1990 19' open bow galaxy. i've read on here that the stringers run the entire length of the boat. after pulling the rotting floor i found that they onlyu go from the transom to about the middle of the boat, then undr the bow they put a gas tank sitting on a platform. is this safe or is it a hack job. I cant tell but looks like they cut the stringers to put the gas tank in. also the pipe thats fiberglassed to the bottom of the hull has the gas line running thru it. is that safe? they closed up the front of this pipe with foam causing the bow of the boat to retain water. after pulling the gas tank, ripping up the gas tank platform and removing the wet foam i found daylight shining through the fiberglass hull, so now i have to build up the hull with fiberglass. that pipe is suppose to be open, right? the gas line is corroded from sitting in water so long, so now that needs to be replaced. does that usually run thru that pipe, or do i have to reroute it? thanks for your help
