Storing a wood boat with 5200 bottom in desert heat
Desertsun
Hi. Restored 1940 chris craft 18’ wooden boat with 5200 bottom.
Planning to store it in an INDOOR storage facility with no climate control in Phoenix where temps reach 115+ and humidity is very low.
Is this a problem for the wood and/or 5200 bottom? I don’t want to ruin a good boat.
Thanks in advance!
cyclops222
A carport with a large sun roof is much better for any wood outdoors. What is a 5200 bottom made of ?
That shed will destroy all wood.
cyclops222
My concern is a inner plywood sheeting. Which stretches & shrinks all directions the same amount. Then laying down nice wood planks that shrink and expand in the same direction. Extreme heat or cold ? Fiberglas every time. I would sell it before it is damaged. Buy a all glass boat.
Desertsun
It would not be outdoors it would be in indoor storage but indoor storage temps could likely be at a high of 110 in the middle of summer and a low of 50 in the middle of winter.
Ned L
Who did the bottom? I would pole a number of shops that have done 5200 bottoms for years and see what they have to say.
I don't see this as a '5200 tech line' question. That glue should have no problem. As you said, it is a question of the stability of he wood in the heat and dry environment.
You might have more troubles with the batten seam topsides.
