FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
It worked fine before we put it away for the winter. Now it won't turn at all. Powersteering resavoir, i tried to bring rpm to see if that would help but nothing. It has a alpha one,
s/n numbers on the outboard is. 0d659479 and od657816
So you cant turn the steering wheel? or the pulley on the ps pump wont turn?
If the pully you need a new pump. They do seize. probably a shaft bearing that got water in it somehow and rusted. Not sure if you can just replace bearing or not in those.
About 99% of the time, it caused by corrosion in the aluminum tube in the power steering cylinder where the cable goes through. The corrosion builds up prevents it moving.
