- Oct 25, 2011
- 25,248
Re: Top secret metal boat files are all hidden!
I 'think' you have to use the advanced reply & below the window where you type a post, there's attached thumbnails.... You might be able to remove it there. But doesn't bother me, just for info..... Often a 3rd grader, so pix are good, even 2 of the same
Same manufacturer, but their 'more' aggressive Epoxy Paint Stripper... Now that is odd, I just went to their website & the stripper I bought isn't listed....... Maybe it's been repackaged & relabeled the KS-3 Premium that you posted. It does have epoxy listed as a paint it will remove........ The can I bought has both red & orange, but is clearly labeled as EPOXY remover.... I printed the MSDS sheet for the KS-3 Premium, and will check it against the one at home......
Anybody want to guess if Aircraft stripper would be better at attacking the bedliner? When I can get through the bedliner, the original cream hull paint comes off too...
It really is paint stripper on a 6"X6" area, give it a few minutes, as soon as it stops bubbling up the little bit it bubbles, scrap it off. Else it starts to collapse & 're-cure'. Then start again. I tried several different plastics to slow the re-cure, and let the stripper chew on the bedliner for a bit longer, but the 4 different I tried didn't do much if anything. Good news is there are no squares of plastic stuck in the re-cured bedliner, so there is that:facepalm:
I'll try to get the bench plank sealed on the bottom tonight, and on Thurs, drop it in place & shoot some pix...
