Sputtering Johnson V4 90hp - 1994
Mc Tool
Drive it like you stole it. Sometimes givin it arseholes does it the world of good ....blow all the crap outa it ....but , if it doesnt clean up and run well dont persevere to long 😁
jimmbo
If I were driving something that I stole, I would be the Best/Smoothest/Most Courteous Driver out there. Why would I do anything that might catch Henry Handcuff's Attention?
Mc Tool
Because if your dumb enough to steel something you wouldnt think of that , and youd be real keen to leave the scene of the crime asap , specially if the cops (Henry handcuffs ....where the hell did you get that ....no, no, I dont really want to know 😆) were already on your arse , its a humourous line " drive it like you stole it " sorta in the same vein as " drives like a lost getaway driver " ....being a tad erratic and likely to make rapid ,badly thought out changes in direction in the height of panic as Elliot Ness and his team of untouchables ( trying to think of something in your age range😁) is closing the gap in hot pursuit , in their wallowing standard federal enforcement sedan , bristling with Colt .38 police positive pistols and Thompson sub machine guns ....while you lost the 7th hub cap off the same car .😂😂😂😂
( and they reckon Germans are humourless ).........🙄...far out jimmbo, your a hard case, and youd make a lousy criminal 😂😂( I mean that in a nice way )
Berdink
Berdink
Post 99
Wow.
It's been so long I basically forgot what your symptoms are? How about a new video. If you make it into a YouTube (easy) it transfers better quality.
Yeah, I'm pushing to make it to a trip in August we've planned for a year now.
Berdink
It's discouraging that I can find several threads where someone asks about an issue similar to mine, the same members lending help, and the person with the issue just disappears. 😕
Berdink
I'm still reading lots of threads learning and learning. I've seen a few threads where someone tells them to test the compression again. So this time I rented a compress tester from Napa.
I got:
126, 134, 126, 128.
I also moved the spark tester out from 7/16 to 1/2 inch and the spark jumps it just fine on all cylinders. The color was blue. Not yellow or orange.
Oh, and as best I can tell the spark is consistent, sparking at each rotation.
I should have time to put the carburetors back on tomorrow.
Once I get it running again, and whether it runs good or not, I'm going run it after dark and look for possible arcing.
Berdink
I checked the ohms on my spark plugs. All 8 of them. No continuity from the threads that go in the block to the top of the spark plug that goes in the spark plug wire boot. But for the test from the top of the spark plug through to the sparking tip, I got all .12, except for one spark plug I got .28
What does that mean?
Berdink
Nevermind, searching testing spark plugs Google says you can't test these spark plugs with a multimedia alone, but must be tested for voltage.
Berdink
I took a vacuum tester and hooked it up to the line that goes from the fuel pump to the carburetor bowls. Pumped it up to 20 and let it sit for 5 minutes.
It didn't drop pressure one bit.
Berdink
Checked every nook and cranny of the carburetors. Every orifice is clear. No matter what hole I spray in, spray comes out the other end. Every passage is clear. I ran copper wire through them all. The largest size that would fit depending. I even bypassed the fuel pump and gravity fed straight to the carburetors. I bought fresh new non-ethanol fuel mixed with 2.6 oz oil, and used straight from the 1 gallon gas can. Pumped the bulb and continued to keep it firm. No change pumping the bulb or not. No change spraying starter fluid around different areas. I'm going to give up on the fuel.
The shop manual and DVA should be here late next week.
Or maybe just buy all new coils, plug wires, stator, power pack, timer base, everything.
I mean seriously! What the heck!
I will run it one more time after dark and see if I can see any arcs / shorts.
Discouraged.
Short Video;
Google Ai:
"Yes. A bad stator can definitely sound, feel, and act just like the engine is sputtering from a lack of fuel, or a lean condition."
jimmbo
Can definitely hear the Miss there. Too bad the Video isn't longer, so as to hear it pattern of repeating
Before you take out a Mortgage to finance all those Parts, have you checked all Connectors for signs of Corrosion and/or intermittent Conductivity?
Berdink
I'll go through all the connections tomorrow. I can't start testing the coils, stator, and power pack for the correct voltage until the DVA I ordered arrives next week.
Berdink
I'm going to take a break on the motor for a bit and quit chasing 'maybe this or that' until the manual and DVA arrives. I'll check the ignition starting from the coils working my way backwards.
I'll rule out the ignition and move on from there.
