Sputtering Johnson V4 90hp - 1994
Berdink
I have a new to me 1994 Johnson 90hp V4.
It started real nice and ran real nice when I first heard it run.
When I ran it more at home, it sputtered some off and on.
I did a strong mix of seafoam to see if that would clear things up.
It didn't.
I read up on the Link & Sync and got everything adjusted as described.
But then it progressively sputters more.
It's been awhile since I've worked on engines. My last was a SBC in a 1965 C10.
Anyway, I remembered the idea to spray carb cleaner around gaskets and linkage and hoses.
When I spray carb cleaner at the bottom of the upper carburetor, it so slows the idle and smooths out. (see pic) - btw, I was pleased to see I had aluminum fuel bowls and not the plastic ones.
This tells me I have an air leak.
I'm going to order a carb rebuild kit and gaskets, but it may just be a leak. I figured if it wasn't just a leak, then I'd still know that I went through the carbs and that at least is good.
Thoughts?
Berdink
I doubt there is an air leak.
But it changes idle significantly when I spray carb cleaner near the bottom of the bowl.
Okay, maybe I should have called it a vacuum leak.
What do you think the issue is?
Either way, I bought two rebuild kits. I can check all the hoses, connections, and seals while I have it apart .
saltchuckmatt
What are you idling at in your driveway rpm wise?
Throat of the carb is grabbing some of your carb cleaner...even if the bowl had a seal problem it would just leak.
1100 out of the water
Post compression numbers.
Idles probably to low.
Berdink
Last time I ran it in a 55 gallon drum cut in half filled well above where the lower unit meets the midsection - probably around 6 inches above the cavitation/ventilation plate.
I need to get a tach.
Cold Compression is around 120psi.
120, 119, 121, and 126 PSI
saltchuckmatt
You can do it by ear....should be high in the barrel and quite a bit less in the lake. As long as it's not slamming into gear when shifting.
Berdink
I'm going clean the carbs, inspect all hose connections, and check everything over.
It's probably time anyway.
