Berdink
Thread starter- Joined
- Mar 5, 2020
- 578
I have a new to me 1994 Johnson 90hp V4.
It started real nice and ran real nice when I first heard it run.
When I ran it more at home, it sputtered some off and on.
I did a strong mix of seafoam to see if that would clear things up.
It didn't.
I read up on the Link & Sync and got everything adjusted as described.
But then it progressively sputters more.
It's been awhile since I've worked on engines. My last was a SBC in a 1965 C10.
Anyway, I remembered the idea to spray carb cleaner around gaskets and linkage and hoses.
When I spray carb cleaner at the bottom of the upper carburetor, it so slows the idle and smooths out. (see pic) - btw, I was pleased to see I had aluminum fuel bowls and not the plastic ones.
This tells me I have an air leak.
I'm going to order a carb rebuild kit and gaskets, but it may just be a leak. I figured if it wasn't just a leak, then I'd still know that I went through the carbs and that at least is good.
Thoughts?
It didn't.
Thoughts?
